Like the title I used Geopay for H/V and it crashed.
All the things was find untill I clicked the start botton.
Below is my crash report.
I didn't face the problem like this in Geopsy, so i really confuse.
i hope that there is some solution you can give me.
thanks
HVSR crash when i click the start botton
- HVSR_bug.txt
- (15.7 KiB) Downloaded 5659 times
Re: HVSR crash when i click the start botton
Launch geopsyland available in the same bin directory as geopsy. It contains the list of the graphical applications distributed with geopsypack in the left panel. On the right panel, there is a light emulation of a Linux bash terminal. Type:
In your crash report, you are running 3.4.1 but you are loading the plugin tools from 3.4.2. It should be better to remove 3.4.1 from your disk. This mix is probably the cause of the crash.
geopsy -clear-toolsBest regards,
I already download 3.4.2 again and remove all others.
On the other hand, I tried the code you shared, but it still crash when HVSR come to click the start button.
Below is the picture with my GeopsyLand. Actually, HVSR still worked 5 days ago and I didn't download anythings with my computure.
The crash problem just appear without reason.
thanks
thanks
- (15.7 KiB) Not downloaded yet
Is there a report after the crash?
If so, can you copy the text here?
The bug collection facility is now repaired but it works only with the latest release to be published in a few days (3.5.0).
