parametrization space by command lines
Hcadet
Post by Hcadet »
Is there any way to create a parametrization space (I mean a toto.param file) by command line (without the dinver interface)?
(and without using gpdepths that is a specific parametrization)
Thanks!
Bye
Heloise
You can generate your own xml content at your own risk. Nearly all "geopsy" formats are compressed xml files. At input, the xml can be compressed (inside a tar structure) or not (plain text).
To have an idea of the xml structure of a .param file:
tar xvfpz toto.param
If toto.param was previously generated by Dinver or gpdepth. This will produce a contents.xml file encoded in UTF-16 (no ASCII). See viewtopic.php?t=8&highlight=iconv for more details.
Once edited, you can rename your file to .param:
mv contents.xml toto.param
