[SOLVED] how to paste passive signal?
riccardo
Post by riccardo »
Good morning
I have a sismograph that can take only 4096 samples, so the passive f-k metod for time period longer than 30" with 125 Hz is impossible.
Is it possible with Geopsy paste/merge two .SU files in one file?
Re: [SOLVED] how to paste passive signal?
There is no need to merge various segments of recordings. Just provide the same station name for all segments with correct starting and ending time. The FK processing will jump from one section to the next
riccardo
Post by riccardo »
thank you MArk
Is it possible to use the dinver with f-k linear passive tool output *.max
.max files are to be pre-processed by max2curve before proceeding to the inversion step.
riccardo
Post by riccardo »
max2curve is very criptic !!! ;-)
It might be at first glance. If you are not used to array processing, you'd better read this http://www.geopsy.org/wiki/index.php/FK ... utput_file about the .max format and explanations about max2curve process.
