I wanted to use max2curve from the f-k conventional too in geopsy, but when I tried to load the already existing *.max file it says "no max result can be loaded". Any idea what may cause that?
thanks, Theodora
max2curve
Re: max2curve
Can you post the first lines of your .max file?
Basically, I would need the first lines starting with "#" and a few data lines just after the last "#".
You get this message because max2curve cannot identify the type of results to analyze (FK, SPAC, plain curve, HVTFA), probably a missing header or an old one.
Re: max2curve
sorry for late reply. It is output of conventional F-K toolbox that I can not visualize with max2curve. Surprisingly, results of F-K for passive experiments can be visualized.
- hyf.txt
- (5.44 KiB) Downloaded 1962 times
Re: max2curve
Your max2curve file is empty. There is nothing else than the header (starting with #)
Check your processing parameters in Geopsy.
