HV save results - Directory choosing
sbirro
Post by sbirro »
when saving HV results Geopsy prompts for the directory where to save them, but it has a misleading behaviour: it saves the results in an *.hv file with the NAME of the chosen folder, but in its PARENT folder.
I don't know if it's the desired way to save the results, but it would be simpler, if possible, to allow to directly specify the name of the *.hv file or at least to save the file in the given folder.
Thanks,
Riccardo
Re: HV save results - Directory choosing
Thanks for report, I'll check and fix it for next minor release
I checked in different ways and I was not able to reproduce the error you reported:
  • Processing several stations, saving from menu "Tool/Save results"
  • Processing several stations, saving with "Output" switch set in "Output" tab
  • Processing one single station, and saving with both methods.
I tried with a blank 'Name' for all signals and effectively it saves the results the way you described it.
This is now fixed for the next minor release (1.4.3). In case of a blank station name, file name is explicitly asked. Also the case if only one station is processed.
sbirro
Post by sbirro »
I usually process exactly one station with a blank name, because in the data acquisition software I use the station name is optional.
Sorry not to mention it and thanks for the fix.
