passive linear fk using active masw
smorton
Post by smorton »
I am trying to process my data using the passive linear fk tool. The data files are actually those from an active MASW survey, but I would like to process it as if it were collected passively. I used 4.5Hz phones (24 channels) with record length = 2.048 seconds, but when I attempt to run the module, the status bar hangs such that there is one bar "Finished" at 100% and a second bar "Finish" but the green bar continuously glides across over and over. My *.max file also appears flat.
Is Geopsy not able to process active MASW data as if it were collected as a passive survey?
Re: passive linear fk using active masw
No there are no restriction. Check that sufficient recording time is available compared to the time window requested.
