Swapping X and Y of a plot with grid value
All geopsy forums are in their very early stage. So a restricted number of forums has been created. If your question does not fit into one of the available categories, post here.
  1. Click on "Export values" (context menu on any plot with grid values), for instance to /tmp/grid
  2. Go into the properties of the layers, under the color map section, save it to /tmp/toto.pal
  3. Run the following script:
    cat grid | awk 'BEGIN{print "x y val"}!/x y/{print $2,$1,$3}' | figue -g -colormap /tmp/toto.pal
  4. Manually edit the properties of the axis to fit your needs.
  5. If you have to repeat it for several plots, you can save the make-up of a plot and add option '-m /tmp/your.mkup' in figue arguments.
Running the command line supposes that you are running Linux or Mac OS. If under Windows, you can install git for Windows. It is shipped with a bash terminal that supports almost all features.
Swapping X and Y in a more user friendly way is an option that will be probably added in the future.
