lack of tools in geopsy 3.2.2 and vars
ESBornand
Post by ESBornand »
Dears, a query in for version GEOPSY 3.2.2, in EDIT there is no SET SOURCES option and to load the geometry with SET RECEIVERS, when loading the geophone geometry from the TXT file and giving OK, and rechecking the geometry deletes them. This is not the case with GEOPSY version 2.9.0, which works well in these cases, but for SPAC, filtering the signal with the SPECTRUM tool creates an error (BUG).
Re: lack of tools in geopsy 3.2.2 and vars
"Edit/Set sources" menu has been removed because source is no longer a property of signals. Instead, there is a an event table (close to "Files" and "Groups"). Events are identified by their absolute time and location. In principle, when loading MASW data from a SEG-2 file, a new source is added to the event table. If it is not the case you can edit the is table (manually or by loading a file).
"Set receivers" should work. If not, can you post your coordinate file and document the error for instance with a snapshot. If I can reproduce the problem, it is easier to fix it.
Can detail the bug you encountered with the spectrum and the SPAC tool?
You can upgrade to 3.3.3. There is no major change except bug fixes.
ESBornand
Post by ESBornand »
Thank you for your answer, I am attaching an error to be analyzed. Regards!
bug reeport spac.zip
(1.51 KiB) Downloaded 2124 times
ESBornand
Post by ESBornand »
Dear, attached file with error to filter SPAC record.
(1.51 KiB) Downloaded 2148 times
Both crash reports were generated with old release < 3.0.0
These releases are no longer supported and they cannot be fixed. To get bug fixed, you have to run version 3.3.3. And eventually submit bugs found only with this version.
ESBornand
Post by ESBornand »
Thanks!!
