I'm using gpell for a number of 1-D models that include Qp and Qs, and have found that there seems to be no change when either adding or changing Qp / Qs in the models, as exemplified with the attached models & resultant ellipticity curves. I've tried this for a number of other models and also with Geopsy 3.5.2 and 3.4.3, with no success. Any ideas on this?
Cheers,
Ian
Viscoelastic computation not working for gpell?
- (72.83 KiB) Not downloaded yet
- test_Q500.txt
- (77 Bytes) Downloaded 4719 times
- test_Q100.txt
- test_Q50.txt
- (75 Bytes) Downloaded 4946 times
- test_Q20.txt
- (75 Bytes) Downloaded 4964 times
Re: Viscoelastic computation not working for gpell?
Hi Ian,
Effectively, gpdc and gpell do only elastic computations. Qs and Qp are included in the file format to get a unique format for 1D structures. The format is also accepted by gpsh which makes use of Qs and Qp.
