About process HV error
Discuss here all technical and scientific questions about the processing of ambient vibrations for site characterization (H/V, Array methods,...)
ESBornand
Post by ESBornand »
Dear, I have some files to process HV *.SEG2, however when processing it throws me a screen and does not allow me to advance, "Add signal id 1 to component Vertical of station R001 at 55 0 0"
I attach reference image and file.
Thanks.
(67.82 KiB) Not downloaded yet
2025-02-25_10-12NAK1.rar
(4.8 MiB) Downloaded 23498 times
IgnazioC
Re: About process HV error
Post by IgnazioC »
Hello,
your data seems to have 2 kinds of problem (see "original data"):
1) they are all loaded as vertical;
2) "Rec o" in "Table", have different values.
You need to edit table values (see "edit - lock table edition" image), with the rigth values of type of sensor per channel and it should work (see "final" image).
Bye
(34.66 KiB) Not downloaded yet
(158.13 KiB) Not downloaded yet
(47.36 KiB) Not downloaded yet
I confirm IgnazioC's comments. A H/V station is supposed to have three components and located at the same coordinates (Receiver X and Y must be the same for all components). You can also modify these values with a script in menu Edit/Set header.
For instance, in your particular case, you should run:
for(i=0; i<signals.length; i+=3) {
  signals[i].component="Z"
  signals[i+1].component="N"
  signals[i+2].component="E"
for(i=0; i<signals.length; i++) {
  signals[i].receiverX=0;
  signals[i].receiverY=0;
  signals[i].receiverZ=0;
Adapt the order of components to your case.
