Geopsy Command line Param file issue
laleh
Post by laleh »
I have been using Geopsy hv command line to process hv files in batch mode. I made an assembled parameters file for this purpose , as you see in the example I wanted to filter my data and I have anti-triggering on, but when I run this in command line I see that the output stated the "anti-triggering on filter data = N". in general I am not sure if this params file is working effectively and applying all the preprocessing on my data. how can I make sure that data is being filtered and STA/LTA is being applied?
Thank you.
Laleh
assembledparameter_2020012214000.txt
(2.45 KiB) Downloaded 5467 times
andrea_V
Re: Geopsy Command line Param file issue
Post by andrea_V »
Good afternoon!
I had the same problem with an older version of Geopsy. Are you running the last version?
laleh
Post by laleh »
Hi Andrea,
Thanks for your reply.
In the batch mode I'm not using the new versions, as these are old results but I wanted to make sure if the filtering was applied to them and avoid regenerating the results.
Does it work fine with the new version? is there a way that you could try to make sure if it's applying all the paramters?
andrea_V
Post by andrea_V »
I'm sorry, with my data your parameters in geopsy 3.5.2 just do not pick any window and i don't understand why... even changing some parameters. I did not check them all though.
Good luck!
Andrea
When running geopsy-hv, the parameters used for processing are listed in the terminal and in the .log file. In the log file there is also a list of the time windows. Check with the graphical interface for a particular case. Are the number of time windows the same with geopsy-hv and within the GUI? Do they exactly match?
laleh
Post by laleh »
Thank you for your reply.
no they don't match, I remember you checked this previously and it's fixed in 3.6. version which I assume is not out yet. I saw your reply to my other post regarding using the git repository to get the new changes. that should work :) (https://www.geopsy.org/forum/viewtopic. ... aleh#p2036)
thank you,
Laleh
